Splitting a polygon is a common technique in GIS which can help process mapping data. Map Suite provides you with the necessary API that allows you to split a polygon with lines or polygons. This sample shows you how to split a polygon with a line. This procedure can be useful for users wanting to split fields, land parcels or any other type of polygon.
Download the ThinkGeo Product Center and start manipulating your data. In addition to this sample many other code samples are available to help you get started with Map Suite quickly.
