Do you use ArcGIS Server? If so, you can now use Map Suite to access your maps that reside on ArcGIS server using Map Suite Development Build 9.0.443.0 or later. This feature was first introduced with Map Suite Web Edition 5.0 as an overlay. However, it is now supported across the various Map Suite Editions as a layer.
This sample demonstrates the new ArcGISServerRestLayer. The ArcGIS Server REST layer provides a built-in means for retrieving geospatial data from ESRI’s ArcGIS Server and displaying it seamlessly within your Map Suite applications. Additional improvements will be made to this sample to support projections, and much more.
With Map Suite developers can create interactive maps and add them to their applications with just a few lines of code.
