Conversion Plan High Level
- List all of the 10 dependency NuGet packages
- Uninstall all 10 NuGet packages
- Install ThinkGeo 12 dependencies
- Tackle the using statements to replace them all at once
- Evaluate the issues that can be mass search and replaced and create a list of them
Conversion Steps Detail
For the conversion we suggest that you create using a source control branch specifically for the upgrade process
List all 10 dependency NuGet packages
Run the following command in the Package Manager Console of Visual Studio. This will list all of the packages that need to be uninstalled. Then make sure to capture that list as we will be using it to install 12 packages.
get-package | Where-Object Id -match 'ThinkGeo|MapSuite' | Where-Object Versions -like '10.*'The output should look like this.
Id Versions ProjectName
MapSuiteDependency-GeoAPI {10.6.0} Sample
MapSuiteDependency-MicrosoftSqlS... {10.6.0} Sample
MapSuiteDependency-MicrosoftVisu... {10.6.0} Sample
MapSuiteDependency-NetTopologySuite {10.6.0} Sample
etc...Uninstall all 10 NuGet packages
We are now going to uninstall of the 10 NuGet packages using the Package Manager Console. This assumes you have no 12 packages installed. If your solution has many project that have references this could take minutes. We also suggest that you do not have the NuGet UI window open as it slows down the uninstall as it need to constantly refresh the UI.
get-package | Where-Object Id -match 'ThinkGeo|MapSuite' | Where-Object Versions -like '10.*' | Uninstall-Package -RemoveDependencies -ForceWe suggest you commit to source control after this step.
Install ThinkGeo 12 NuGet packages
Install the ThinkGeo.Core and ThinkGeo.UI.{PLATFORM} v12 NuGet packages to each projects that had references to the ThinkGeo v10 packages listed in the first step.
Replace Using statements
Perform a solution-wide search and replace for the following using statements:
| v10 | v12 |
| using ThinkGeo.MapSuite; | using ThinkGeo.Core; |
| using ThinkGeo.MapSuite.WinForms; | using ThinkGeo.UI.WinForms; |
| using ThinkGeo.MapSuite.Styles; | |
| using ThinkGeo.MapSuite.Drawing; | |
| using ThinkGeo.MapSuite.Shapes; | |
| using ThinkGeo.MapSuite.Layers; | |
| using ThinkGeo.MapSuite.Portable; | |
| using ThinkGeo.MapSuite.Serialize; |
Note that in some cases the
using ThinkGeo.MapSuite;may not have been added. There may be many error becauseusing ThinkGeo.Core;is not referenced. You will manually need to go into each file and ensure theusing ThinkGeo.Core;is there.
NOTE: For WinForms applications, make sure to add a reference to the WindowsFormsIntegration assembly to each project that uses the WinformsMap.
Replace Common API Changes
| v10 | v12 |
ExtentHelper. |
MapUtil. |
AreaStyles. |
AreaStyle. |
LineStyles. |
LineStyle. |
PointStyles. |
PointStyle. |
TextStyles. |
TextStyle. |
GeoColor.StandardColors. |
GeoColors. |
GeoColor.GeographicColors. |
GeoColors. |
GeoColor.SimpleColors. |
GeoColors. |
.BestPlacement = true |
.TextPlacement = TextPlacement.AutoPlacement |
.BestPlacement = false |
.TextPlacement = TextPlacement.Default |
TextStyle.PointPlacement = PointPlacement. |
TextStyle.TextPlacement = TextPlacement. |
DrawingQuality.CanvasSettings |
DrawingQuality.Default |
GeoFileReadWriteMode. |
FileAccess. |
FillSolidBrush.Color = GeoColor.FromArgb( |
FillBrush = new GeoSolidBrush(GeoColor.FromArgb( |
TextStyle.TextSolidBrush |
TextStyle.TextBrush |
InteractiveOverlayDrawType.Draw |
InteractiveOverlayUpdateMode.Update |
InteractiveOverlayDrawType.DoNotDraw |
InteractiveOverlayUpdateMode.DoNotUpdate |
InteractiveOverlayDrawType.Default |
InteractiveOverlayUpdateMode.Default |
WinformsMap |
MapView |
.RestrictedExtent |
.RestrictExtent |
AdornmentLayersDrawingEventArgs |
DrawingAdornmentLayersEventArgs |
AdornmentLayerDrawingEventArgs |
DrawingAdornmentLayerEventArgs |
AdornmentLayersDrawnEventArgs |
DrawnAdornmentLayersEventArgs |
AdornmentLayerDrawnEventArgs |
DrawnAdornmentLayerEventArgs |
GeoCanvas.CreatePlatformGeoCanvas |
GeoCanvas.CreateDefaultGeoCanvas |
MapUtil.SnapToZoomLevel |
MapUtil.GetSnappedExtent |
GetAccurateLength |
GetLength |
.DrawThisOverlay |
.InteractiveOverlayUpdateMode |
Proj4Projection |
ProjectionConverter |
FeatureSource.Projection |
FeatureSource.ProjectionConverter |
InternalProjectionParametersString |
InternalProjection.ProjString |
ExternalProjectionParametersString |
ExternalProjection.ProjString |
Note that there were a number of changes in the EventArgs of many of the ThinkGeo classes where we switched the position of the verb from the middle to the front. For example the
AdornmanetLayerDrawingEventArgschanged toDrawingAdornmanetLayerEventArgs. We do not list all of these changes it will vary by project how many of these might have been used. As long as you know the pattern it should be easy to change them. Be sure to notice small difference in the names such as in the previous example there is aAdornmanetLayerDrawingEventArgsand aAdornmanetLayersDrawingEventArgswhich look very similar.
Getting Help
If you need additional help just let us know by opening a support ticket and we can help with some of the trickier conversion items not covered by this guide.
Not Supported
What we can do for the below is publish the code for these classes with the conversion documentation. WorldStreetsAreaStyle WorldStreetsLineStyle WorldStreetsPointStyle
We do not support non snapping maps. We need to think about how to make a nice path toward this and users who want to set the scale precisely. We could offer a zoom level set that included 100 zoom levels or more but we would need to test this out. WinformsMap.ZoomLevelSnapping
