Are you looking to edit the colors on your map to make it stand out? For example, let’s say you have an 8-bit raster image and you want to identify and replace the colors in order to make your maps more visually appealing. Map Suite now supports a new color mapping API that allows developers to handle such cases.
This new API works with the other existing color related properties such as transparency, gray-scale, etc. which helps you add meaning to your maps. In addition, this is a core API and can be used across the various Map Suite SDKs. Download the sample directly from GitHub and start adding meaning to your GIS app quickly.
